msfc module 15
mahesh18
Level 6
Level 6
hi all,
i want to know on cat os 6509 msfc is plugged on the supe engine in slot1 then
why it shows on sh mod that it is on module 15?
(enable) sh mod
Mod Slot Ports Module-Type Model Sub Status
1 1 2 1000BaseX Supervisor WS-X6K-S2U-MSFC2 yes ok
15 1 1 Multilayer Switch Feature WS-F6K-MSFC2 no ok
3 3 16 1000BaseX Ethernet WS-X6516-GBIC no ok
4 4 16 1000BaseX Ethernet WS-X6516-GBIC no ok
5 5 48 10/100BaseTX Ethernet WS-X6348-RJ-45 yes ok
6 6 16 1000BaseX Ethernet WS-X6516-GBIC no ok
Mod Module-Name Serial-Num
1 SAL0605HFG1
15 SAL06090N1R
3 SAL0706CRDB
4 SAL0706CTHW
5 SAL0652APS7
6 SAL0807UFW1
Mod MAC-Address(es) Hw Fw Sw
1 00-06-d6-5a-a5-d6 to 00-06-d6-5a-a5-d7 3.10 7.1(1) 8.5(9)
00-06-d6-5a-a5-d4 to 00-06-d6-5a-a5-d5
00-0b-60-f6-80-40 to 00-0b-60-f6-84-3f
15 00-09-b7-95-32-40 to 00-09-b7-95-32-7f 2.4 12.1(27b)E 12.1(27b)E1
3 00-06-d6-5c-81-78 to 00-06-d6-5c-81-87 5.3 6.3(1) 8.5(9)
4 00-06-d6-5c-80-c8 to 00-06-d6-5c-80-d7 5.3 6.3(1) 8.5(9)
5 00-0b-be-d3-e1-20 to 00-0b-be-d3-e1-4f 6.2 5.4(2) 8.5(9)
6 00-0f-24-1a-90-d0 to 00-0f-24-1a-90-df 5.5 6.3(1) 8.5(9)
Mod Sub-Type Sub-Model Sub-Serial Sub-Hw Sub-Sw
1 L3 Switching Engine II WS-F6K-PFC2 SAL06121ALJ 3.2
5 Inline Power Module WS-F6K-VPWR 2.0 1.1(1)
many thanks
mahesh
2 Accepted Solutions
Jon Marshall
Mahesh
The supervisor communicates with the MSFC via an internal trunk and that trunk is on port 15/1.
Jon
Giuseppe Larosa
Hello Mahesh,
technically an MSFC2 is a daughter card installed on the supervisor.
As noted by Jon supervisor sees the MSFC via port 15/1.
The usage of slot 15 is a convention to indicate that this is a logical slot being the biggest chassis the C6513.
if you have two sup2/MSFC2 in the same chassis the second MSFC is seen as slot 16.
Hope to help
Giuseppe
Jon Marshall
Mahesh
Jon
Giuseppe Larosa
Hello Mahesh,
Hope to help
Giuseppe
Thanks for great reply
