MST Loop Effect Question
Cloudy
i have some question
if loop occur on some vlan. it will effect all vlan on same instance or not ? or effect to another instance ?
Rolf Fischer
Level 9
Level 9
The scope of a bridging loop is normally the broadcast domain, which is a single VLAN. But if it results in the maloperation of one switch, the whole LAN can be affected.
STP's purpose is to prevent bridging loops, so with STP enabled, a loop should no occur.
The former standard-based STP versions (802.1D, RSTP) prevent the occurence of bridging loops on a per-port basis regardless of the VLAN(s) assigned to a port; the Cisco proprietary versions do that on a per-VLAN basis and with MSTP it's done on a per-instance basis. The ST topology and the status of the instance applies to all VLANs mapped to that instance.
Instance 0 is a special case, because it also interacts with other regions/boundaries if they exist.
Hope that helps
Rolf
Rolf Fischer
Level 9
Level 9
Hope that helps
Rolf
