MTU on 3560
ogadri
Is it possible modify the MTU (per interface) on the 3560 EMI switches? If not per interface, is it possible at least as global command? (C3560-IPSERVICESK9-M), Version 12.2(25)SEE2)
andrew.burns
Level 7
Level 7
You can set the mtu globally with the "system mtu" command - but best to read the entry in the command reference first because there are a number of caveats (like having to reset the switch if you change it).
Andrew.
andrew.burns
Level 7
Level 7
Andrew.
devang_etcom
Level 7
Level 7
http://www.cisco.com/en/US/products/hw/switches/ps5528/products_configuration_guide_chapter09186a0080774224.html#wp1154596
take a look on this link you can change the system MTU...
rate this post if it helps
regards
Devang
