Mulitcast Filtering
gpavledes
Is there a way to disable multicast filtering through the CLI on the Cisco Catalyst 9200L?
You meaning igmp snooping? If yes then you can disbale snooping and run static.
No, I disabled that already.
Is IP IGMP Filtering the same as Multicast Filtering?
if I am right Yes there is no multicast filter there is igmp snooping
