multi layer switch - cisco packet tracer
gl94
I am not able to ping any switch from router 3. How do i set up default-gateway for this switch ( not the default-network)
5 Replies 5
Diana Karolina Rojas
Are you using this switch as a Layer 2 or Layer 3 device? do you have routes and SVIs configured in your switches?
layer 2.
but the issues is solved.i had given "no ip routing" command previously.
Thanks for your help though.
Julio E. Moisa
Could you please share your configuration?, are you using any routing protocol? The default-gateway can be configured using: ip default-gateway <Gateway IP of your management Vlan>, it is useful to enable the access for remote access through vty lines.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Yes, I am using OSPF.
The issues is solved, I realized that I have disabled the routing by "no ip routing" command ( was following the tutorial :p).
But thanks for help though.
Good to know
Have a great day
