05-10-2019 12:07 AM
Hello Experts,
I have two SW A and SW B switches, they are interconnected with each other via a Level 2 link.
On the switch A is connected a server Multicast connected to a port in vlan 50 in access, on swA the level 2 link is interconnected on port in access vlan 50, while the port on switch B (remote site) is in access vlan 400, the IP receiver (multicast) is connected on port in access vlan 400.
The receiver is in the state that locks and unlocks the multicast, do you have any suggestions in this regard?
IGMP is active on both swa and swb.
Here in enclose the scenarion
Thanks in advance
Ziggy
Solved! Go to Solution.
05-10-2019 03:03 AM
Hello
@Ziggy74 wrote:
Hello Experts,
No sure what you mean by this, does the host receive the MC stream ?
Do you have igmp snooping enabled?
05-10-2019 03:03 AM
Hello
@Ziggy74 wrote:
Hello Experts,
05-10-2019 07:42 AM
what kind of Multicast Server is this and what is the Ip address of MC Server.
can you post show ip pim interface and show ip mroute to understand
would nice if you can post pit the switch config also.
