Multicast application not working
daviflong1979
Community Member
I have a multi-VLAN network on which we are running live stats from a server (on VLAN6) out to a client (on VLAN2) using multicast. I am using Cisco 3560 switches to route ip traffic between VLANs but they are only running IPBase software so can not add mroute config into the VLAN. So I have enabled IGMP on all switches and a snooping querier on the main L3 3560 (as I believe this will allow routing between the VLANs). I am seeing all the snooping groups and can see the mcast IP addresses used by the systems but the traffic will not flow.
I can not ping the mcast IP Address and can not see anything joining the groups. Other mcast traffic is visible and I can see devices joined there but not on the specific group I am looking at. Here are the config specifics
Server Port Config
interface GigabitEthernet0/1
switchport access vlan 6
speed 100
duplex full
srr-queue bandwidth share 10 10 60 20
srr-queue bandwidth shape  10  0  0  0
queue-set 2
mls qos trust cos
auto qos voip trust
Switch VLAN 6 IGMP
Vlan 6:
IGMP snooping                       : Enabled
IGMPv2 immediate leave              : Disabled
Multicast router learning mode      : pim-dvmrp
CGMP interoperability mode          : IGMP_ONLY
Robustness variable                 : 2
Last member query count             : 2
Last member query interval          : 1000
3560 L3 Switch IGMP Details
#show ip igmp snooping querier
Vlan      IP Address               IGMP Version   Port
1         10.203.2.3               v2            Switch
2         10.203.2.3               v2            Switch
3         10.70.203.3              v2            Switch
4         10.71.203.3              v2            Switch
5         10.72.203.46             v2            Switch
6         10.71.203.66             v2            Switch
Global IGMP switch querier status
admin state                    : Enabled
admin version                  : 2
source IP address              : 0.0.0.0
query-interval (sec)           : 60
max-response-time (sec)        : 10
querier-timeout (sec)          : 120
tcn query count                : 2
tcn query interval (sec)       : 10
Vlan 1:   IGMP switch querier status
elected querier is 10.203.2.3      (this switch querier)
admin version                  : 2
source IP address              : 10.203.2.3
tcn query count                : 2
operational state              : Querier
operational version            : 2
tcn query pending count        : 0
Vlan 2:   IGMP switch querier status
admin version                  : 2
tcn query count                : 2
Vlan 3:   IGMP switch querier status
elected querier is 10.70.203.3     (this switch querier)
admin version                  : 2
source IP address              : 10.70.203.3
tcn query count                : 2
Vlan 4:   IGMP switch querier status
elected querier is 10.71.203.3     (this switch querier)
admin version                  : 2
source IP address              : 10.71.203.3
tcn query count                : 2
Vlan 5:   IGMP switch querier status
elected querier is 10.72.203.46    (this switch querier)
admin version                  : 2
source IP address              : 10.72.203.46
tcn query count                : 2
Vlan 6:   IGMP switch querier status
elected querier is 10.71.203.66    (this switch querier)
admin version                  : 2
source IP address              : 10.71.203.66
tcn query count                : 2
Groups on L3 Switch
FR-LYON-3560-CS2#show ip igmp snooping groups
Vlan      Group                    Type        Version     Port List
2         230.0.0.2                igmp                    Fa0/9
5         230.0.0.1                igmp                    Gi0/1
6         230.0.0.1                igmp                    Gi0/1
I have a feeling I will have to put a new version of IOS on the switches to enable mrouting in the VLAN configuration but if anyone can advise then that would be greatly appreciated
jonathanaxford
Level 8
Level 8
Hi David,
It looks to me like you will need to upgrade to an image that supports multicast routing in order to get the multicast to flow between VLANs... That way you can enable PIM on the relevant VLAN interfaces and things should start to move through...
As far as I know, the IGMP snooping querier is used to forward IGMP membership queries on interfaces where PIM is not enabled - you still need to have a multicast router to actually do the forwarding of the traffic.
Many thanks
Jonathan
