Switching
Get 20% off switches when you combine Cisco solutions
Labels
Hallo All! What is the reason that when enabling Telemetry on C9300 Series Switches, only Application Name, Usage and Througput are shown? Switches configured with telemetry show only Application Visibility (Name and Throughput) in DNA center. Why is...
I just created a vlan, assigned it to a port on our 6509, assigned the vlan an ip address and when i shoot the command, show int vlan 31 it says that the vlan is administratively down. I can't figure out whats going on here? i issued a no shut, to no...
Is there something different about configuring SSH on a 9407 with a C9400-SUP-1?  Currently there's no configuration on the device except for an IP address on the management port and ssh.  I've gone through the same procedures we've always used and v...
Hello,I am still considering wheter to deploy Catalyst1000 or CBS350 switch at our small office(15-25 devices).Switch have to be configured with multiple SVIs and DHCP server pools for each + few static routes.I would like to secure MGMT access to th...
kralopafo by Level 1
  • 109 Views
  • 1 replies
we had a daily-basis ip conflict with dhcp server on cisco switch 4506E specially after replacing some the users' ports or a user using the laptop and moves alot, the ip conflict is detected using GARP method.note: the user could try multible free IP...
Greetings!So I was practicing to configure VTP and VLANs. For a start, I created 3 switches (only 2 being turned on). The trunks are working fine as the switches are able to acquire an IP addresses via dhcp from a dedicated router and vtp appears to ...
turtle666 by Level 1
  • 114 Views
  • 6 replies
Hi,I have a C9200L-48P switch with 4x1G uplink module.Port Gi1/1/1 does not have an LED blinking when connected to another switch.Ports Gi1/1/2-4 seem to work fine.Could anyone please guide me on troubleshooting the port and also advise action?
Ranjita by Level 1
  • 84 Views
  • 2 replies
The VLANIF of the core switch acts as the gateway for client. The Client is unable to obtain the gateway IP, but by manually adding ARP, it can communicate with the gateway. The core switch has the correct MAC and ARP information for the client, a...
Translator by Community Manager
  • 87 Views
  • 1 replies
