Multicast between subnets
dtom
We are trying to get multicast to work between two subnets but cannot seem to get it to work  We have the following configuration
multicast video - teradek cube - 10.223.21.101
  multicast - 239.1.254.1
  rtsp://10.223.21.101/stream1
client-a - 10.223.21.100
switch-a - 2960
router-a - 3725 - 10.223.21.1 (fa0/0.1)
fa0/1 - 10.0.10.9
fa0/1 - 10.0.10.101
router-b - 3725 - 10.223.99.1 (fa0/0.1)
switch-b - 2960
clent-b - 10.223.99.200
Client A and the multicast video server are connected to switch-a
Client B is connected to switch-b
Client A can access the multicast video
Client B cannot access the multicast video
Here is the configs
router-a
ip multicast-routing
int fa0/0
  no ip addr
int fa0/0.1
  desc local network
  encap dot1q 1 native
  ip addr 10.223.21.1 255.255.255.0
  ip pim sparse-mode
int fa0/1
  ip addr 10.0.10.9 255.255.255.0
  ip pim sparse-mode
ip pim autorp listner
ip pim send-rp-announce fa0/1 scope 8
ip pim send-rp-discovery fa0/1 scope 8
router-b
int fa0/0
  no ip addr
int fa0/0.1
  desc local network
  ip addr 10.223.99.1 255.255.255.0
  ip pim sparse-mode
int fa0/1
  ip addr 10.0.10.101 255.255.255.0
  ip pim sparse-mode
There aren't any joins on the 'B' side. Verify the client's application TTL setting is greater than 1.
John Blakley
Can you post a quick diagram of how this is connected?
Also, can you post:
sh ip pim interfa
sh ip pim rp
sh ip mroute 239.1.254.1
sh ip pim rp mapping
sh ip pim autorp
HTH,
John
HTH, John *** Please rate all useful posts ***
Here is how things are connected:
router - 10.223.21.1
er-SPARE2#sh ip pim inter
Address          Interface                Ver/   Nbr    Query  DR     DR
                                          Mode   Count  Intvl  Prior
10.223.21.1      FastEthernet0/0.1        v2/S   0      30     1      10.223.21.1
10.0.10.9        FastEthernet0/1          v2/S   1      30     1      10.0.10.101
er-SPARE2#sh ip pim rp
Group: 239.1.254.1, RP: 10.0.10.9, v2, v1, next RP-reachable in 00:01:09
Group: 239.255.255.250, RP: 10.0.10.9, v2, v1, next RP-reachable in 00:00:45
Group: 228.67.43.91, RP: 10.0.10.9, v2, v1, next RP-reachable in 00:01:09
er-SPARE2#sh ip mroute 239.1.254.1
IP Multicast Routing Table
Flags: D - Dense, S - Sparse, B - Bidir Group, s - SSM Group, C - Connected,
       L - Local, P - Pruned, R - RP-bit set, F - Register flag,
       T - SPT-bit set, J - Join SPT, M - MSDP created entry,
       X - Proxy Join Timer Running, A - Candidate for MSDP Advertisement,
       U - URD, I - Received Source Specific Host Report,
       Z - Multicast Tunnel, z - MDT-data group sender,
       Y - Joined MDT-data group, y - Sending to MDT-data group
Outgoing interface flags: H - Hardware switched, A - Assert winner
Timers: Uptime/Expires
Interface state: Interface, Next-Hop or VCD, State/Mode
(*, 239.1.254.1), 00:00:29/stopped, RP 10.0.10.9, flags: SJC
  Incoming interface: Null, RPF nbr 0.0.0.0
  Outgoing interface list:
    FastEthernet0/0.1, Forward/Sparse, 00:00:29/00:02:38
(10.223.21.103, 239.1.254.1), 00:00:27/00:02:58, flags: PT
  Incoming interface: FastEthernet0/0.1, RPF nbr 0.0.0.0
  Outgoing interface list: Null
er-SPARE2#sh ip pim rp mapping
PIM Group-to-RP Mappings
This system is an RP (Auto-RP)
This system is an RP-mapping agent (FastEthernet0/1)
Group(s) 224.0.0.0/4
  RP 10.0.10.9 (?), v2v1
    Info source: 10.0.10.9 (?), elected via Auto-RP
         Uptime: 19:09:00, expires: 00:02:59
er-SPARE2#sh ip pim autorp
AutoRP Information:
  AutoRP is enabled.
  AutoRP groups over sparse mode interface is enabled
PIM AutoRP Statistics: Sent/Received
  RP Announce: 5302/4055, RP Discovery: 5345/0
router - 10.223.99.1
er-CARVER#sh ip pim inter
10.223.99.1      FastEthernet0/0.1        v2/S   0      30     1      10.223.99.1
10.0.10.101      FastEthernet0/1          v2/S   1      30     1      10.0.10.101
er-CARVER#sh ip pim rp
er-CARVER#sh ip mroute 239.1.254.1
Group 239.1.254.1 not found
er-CARVER#sh ip pim rp mapping
         Uptime: 19:09:03, expires: 00:02:47
er-CARVER#sh ip pim autorp
AutoRP Information:
  AutoRP is enabled.
  RP Announce: 0/0, RP Discovery: 0/4081
er-CARVER#
That was it, the TTL setting.  Thanks.
