Multicast/OTV within VRF problem
frodestra
I've been struggling making multicast work across two DC. I'm able to see the sources when I do show ip mroute, but no traffic is going between recievers and source, only I can see traffic generated from local source when I do  show ip mroute summary. I've been trying back and fourth with rp's, msdp, anycast-rp and mdt and enabled ip pim sparse-mode on all links that I know of including the update source loopback for BGP, also I have redistributed the IP's of the RP's into to BGP
The configuration snippets below are from one of the devices
Router# sh ip mroute vrf OTV
IP Multicast Routing Table for VRF "OTV"
(*, 232.0.0.0/8), uptime: 23:47:11, pim ip
  Incoming interface: Null, RPF nbr: 0.0.0.0
  Outgoing interface list: (count: 0)
(*, 239.1.1.1/32), uptime: 1d03h, ip pim igmp
  Incoming interface: loopback5, RPF nbr: 192.168.1.103
  Outgoing interface list: (count: 1)
    port-channel5, uptime: 1d01h, igmp
(10.8.6.241/32, 239.1.1.1/32), uptime: 00:03:36, pim mrib ip msdp
  Incoming interface: mti21, RPF nbr: 10.8.0.1, internal
    port-channel5, uptime: 00:03:36, mrib
(10.8.6.245/32, 239.1.1.1/32), uptime: 00:06:26, pim mrib ip msdp
  Incoming interface: mti21, RPF nbr: 10.8.0.2
    port-channel5, uptime: 00:06:26, mrib
(10.8.6.254/32, 239.1.1.1/32), uptime: 1d01h, ip mrib pim
  Incoming interface: port-channel5, RPF nbr: 10.8.6.254
    port-channel5, uptime: 1d01h, mrib, (RPF)
Router# sh ip mroute su vrf OTV
Total number of routes: 5
Total number of (*,G) routes: 1
Total number of (S,G) routes: 3
Total number of (*,G-prefix) routes: 1
Group count: 1, rough average sources per group: 3.0
Group: 232.0.0.0/8, Source count: 0
Source          packets      bytes           aps   pps       bit-rate     oifs
(*,G)           0            0               0     0         0.000   bps  0
Group: 239.1.1.1/32, Source count: 3
(*,G)           3            4326            1442  0         0.000   bps  1
10.8.6.241      0            0               0     0         0.000   bps  1
10.8.6.245      0            0               0     0         0.000   bps  1
10.8.6.254      4673         6757154         1445  0         5.013   kbps 2
Router# sh run vrf OTV
version 6.1(2)
vrf context OTV
  ip pim rp-address 192.168.1.103 group-list 224.0.0.0/4
  ip pim ssm range 232.0.0.0/8
  ip pim pre-build-spt
  ip msdp originator-id loopback6
  ip msdp peer 192.168.2.101 connect-source loopback6
  ip msdp peer 192.168.2.102 connect-source loopback6
  rd 65512:13
  mdt default 232.0.0.0
  no mdt enforce-bgp-mdt-safi
  address-family ipv4 unicast
    route-target import 65512:13
    route-target export 65512:13
router bgp 65512
  vrf OTV
    address-family ipv4 multicast
      redistribute direct route-map CONNECTED
interface loopback5
  vrf member OTV
  ip address 192.168.1.103/32
  ip pim sparse-mode
interface loopback6
  vrf member OTV
  ip address 192.168.2.103/32
  ip pim sparse-mode
interface port-channel5
  description S1-OTV-Join
  mtu 9216
  vrf member OTV
  ip address 10.8.6.253/30
  ip pim sparse-mode
  ip igmp version 3
Lei Tian
Does the OTV VRF has anything to do with OTV? If yes, I remember pim can not be enabled on otv join interface.
HTH,
Lei Tian
thats correct we have OTV vdc connected to the core network. PIM is not enabled on the join - interface in the OTV vdc. The output above is from the core network, and the routers (VDCs) are directly connected via dark fiber so no ISP blocking multicast.
Can you post the topology, and the multicast group, source IP that is in question?
HTH,
Lei Tian
from the OTV vdc I have the following:
interface port-channel6
  description Join-interface
  mtu 9216
  ip address 10.8.6.254/30
  ip igmp version 3
interface Overlay1
  description Overlay interface
  otv isis authentication-type md5
  otv isis authentication key-chain xxx
  otv join-interface port-channel6
  otv control-group 239.1.1.1
  otv data-group 232.239.1.0/24
  otv extend-vlan xxx
  no shutdown
I have verified IP connectivity by pinging the different Join-interfaces from each other. OTV functiones when I've configured the overlay with unicast. The displayed multicast config from the Router above is from router in DC C. I have also attached the multicast config from DC A and B
