Multicast packet treatment on switches
ambi
Experts i am currently working on multicast and have few queries
How does a switch treat a multicast packet (non igmp) when there is no source sending traffic for that multicast group.
how does an L2 switch treat a ipv6 MLD packet (which is multicast) when neither ipv6 or MLD is configured on the routers
how are the switches coded to treat well known multicast mac address like 33:33:xx:xx:xx:xx etc
Ambi
Peter Paluch
Hi ambi,
In my following answers, I assume that we have a simple Layer2 switch that has no specific support for IGMP Snooping or MLD Snooping - let's just assume it is a plain simple switch like the one installed into a common home DSL router. If you want to know how the switches with IGMP Snooping or MLD Snooping react then please say so - keep in mind that things are more complex on those switches.
I do not understand this statement. If there is a multicast packet then someone must have sent it - and that device is the source of that multicast packet, right?
In any case, a simple basic Layer2 switch will flood any multicast packet out all ports (in the same VLAN if the switch supports VLANs) except the incoming port.
A simple basic Layer2 switch will flood such MLD packet out all ports (in the same VLAN) except the incoming port.
They are not coded for such multicast MAC addresses at all. It is completely sufficient that they operate using basic bridging/switching rules that have existed since the first bridges and switches came to existence: If a switch does not know the destination MAC address, it will flood the frame out all ports except the incoming port. Because multicast MAC addresses such as 33:33:xx:xx:xx:xx are never used as source MAC addresses and thus can never be learned by a switch, they will always be treated as unknown destinations for which the traffic is always flooded. You do not need any specific support on switches for basic multicast delivery.
Best regards,
Peter
Peter
yes the switches do support IGMP snooping. what i meant by my first point was that what happens if a receiver requests a multicast stream when no source is sending traffic on that address
If there is no specific algorithm that a switch uses to identify well known multicast mac address , then will it always flood those out of all ports in that vlan ? i thought they are punted to the CPU for further processing else it means any NLB packets are always flooded out of all ports
Ambi
