10-04-2017 07:54 AM - edited 03-08-2019 12:15 PM
Hi everyone,
i am trying to implement multicasting on some switches for cctv and it seems to not work as it should.
i have a 3650 L3 as core with multiple vlans. all the svis for vlans is on that L3 and then trunked on to sg300 where cameras connect to. i have enabled ip multicast routing on 3650 and typed ip pim sparse-mode under vlan interfaces. cameras are programmed to advertise on multicast address. however when multicasting enabled i can ping the cameras but strugling to web browse into it. it feels that network is getting fludded. is there anything i am missing like any other configurations on sg300 switches which are acting as L2.
10-04-2017 08:20 AM
Have you designated an RP (rendevous point) for your sparse mode environment?
10-04-2017 08:24 AM
yep created loopback adress and designated rp.
interface Loopback1
description * Multicast - AnycastRP *
ip address 192.168.1.1 255.255.255.25
ip pim rp-address 192.168.1.1
ip pim spt-threshold infinity
10-04-2017 08:28 AM
I haven't used them much but is IGMP snooping enabled on the SG300s? If it isn't that may be causing the suspected flooding.
10-04-2017 09:02 AM
would i have to enable IGMP per vlan?
10-04-2017 09:04 AM
I think you would be OK if you just enabled it globally.
