Multilayer vPC for DCI Solution
opnineopnine
Hi all,
I have a customer and I need to configure DCI, Im using as reference the Quick Start Guide vPC, I know that I cant use a L3 for this, my question is how should I have this configured what type of vpc to use?
thanks.
9 Replies 9
Ganesh Hariharan
Hi all,
thanks.
234
Is both the DC are fully meshed connected or point to point with DCI switches.
Check out the below document for DCI interconnect with good example.
vPC N7k DCI
Hope it Helps..
-GI
Rate if it Helps..
Hello Ganesh,
I will check it, we are usgin dark fiber, will this make and difference in the config?
thanks.
Hello Ganesh,
I will check it, we are usgin dark fiber, will this make and difference in the config?thanks.
Dark Fiber is physical medium connectivity between buildings, Just make sure your provider support ip protocol support over dark fiber.
Hope it Helps..
Rate helpful Posts
But can i have the dark fiber with L2 or only L3?
Thanks.
Thanks.
That depends on your design how you want to have interconnection between Data center either in layer 2 or layer 3. So based on requirement you can have appropriate configuration between DCI for both the DC netwrok connectivity.
Hope it Helps..
Rate Helpful Posts
Ganesh,
One more question can I have a vpc via dark fiber also I will configure the hsrp isolate via the same interface.
thanks.
If you have the money, you can have whatever design you want! How many links are you utilizing between sites?
I have 1 L2 and then will and a L3.
thanks.
Ganesh,
thanks.
267
See you can configure vPC over dark fiber, Dark fiber is physical medium over which ip protocol are supported.
Hope it Helps..
-GI
Rate Helpful Posts
