Multilink with load balancing Question
xbaha12345
Hello, i have the following configuration to load balance my 2 dsl connections, the first question is, will this load balance the outgoing & incomming traffic?
the second question, each line is 4Mbps, i would like to create a Multilink group so that i can utilize the full bandwidth (total 8Mbps), can someone suggest a configuration that work both with load balancing, redundency & giving you the maximum bandwith ?
thanks for any suggestions.
version 12.4
hostname MANS-3660
boot-start-marker
boot-end-marker
no logging buffered
enable secret xxx
no aaa new-model
ip cef
ip name-server xxx.xx.xx.x
username xxx password 0 xxxx
interface FastEthernet0/0
ip address 10.10.10.3 255.255.255.0
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
duplex auto
speed auto
interface FastEthernet0/1
ip address 10.10.100.5 255.255.255.0
ip nat inside
duplex auto
speed auto
interface ATM1/0
no ip address
no ip route-cache cef
no ip route-cache
no atm ilmi-keepalive
dsl operating-mode auto
pvc 0/35
dialer pool-member 1
protocol ppp dialer
interface ATM1/1
no ip address
pvc 0/35
dialer pool-member 2
protocol ppp dialer
interface Dialer1
description SPS_DSL_01
mtu 1492
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp chap refuse
ppp pap sent-username xxx password 0 xxx
ppp multilink
interface Dialer2
description SPS_DSL_02
mtu 1492
ip nat outside
encapsulation ppp
dialer pool 2
dialer-group 2
ppp chap refuse
ppp multilink
ip http server
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 0.0.0.0 0.0.0.0 Dialer2
ip nat inside source route-map SPS_DSL_01 interface Dialer1 overload
ip nat inside source route-map SPS_DSL_02 interface Dialer2 overload
access-list 1 permit 10.10.10.0 0.0.0.255
dialer-list 1 protocol ip permit
route-map SPS_DSL_02 permit 10
match ip address 1
match interface Dialer2
route-map SPS_DSL_01 permit 10
match ip address 1
match interface Dialer1
5 Replies 5
ajaykumar2k1
Dear sir
r these DSL connection are from same ISP or different ISP.
Ajay
Both DSLs are from the same ISP.
why cant i load balance the incoming with DSL???
How could you possible control routing with dynamically assigned IP's? BGP is the only routing protocol (on the public domain) that can even think about providing that. You can try Round Robin DNS, but that's a crapshoot at best.
Collin Clark
This will not load balance in, you will never get that with DSL. You can make it load balance out, but I *think* your route-maps are preventing it. The rest of it looks good.
will it share the load (load sharing per destination enabled) ?
the question is using NAT, will all packets of a session flow through the same dialer interface?
