Multimode at 1Km
mark.hall
I have a couple of 2950's I need to connect over a length of multimode fibre (50/125), my problem is that the total length is nearly 1Km. I'm aware that the maximum distance the cisco GBics etc and SFP's are a maximum of 550m - but I need more!!
Any suggestions would be greatly appreciated (expect change the fibre to single mode which I cant do!!!)
Many Thanks,
Mark.
5 Replies 5
e.claveau
I think what you're looking for is a multimode conditioning cable (CAB-GELX-625). Although you need LX/LH (singlemode) GBIC's for it to work.
Thanks for the response. I think I'll go for a media converter instead which will give me a 'guaranteed' service up to 2Km on multimode (alebit with a reduced throughput of 100Mbps which is fine for this application).
Well here is the pickle, an SFP is produced by a Cisco competitor that will do Gigabit over multimode for a max distance of 2 KM. If your switch is a 2950G then use the command "service unsupported-transceiver" ( this is a hidden command )on the switch reboot it and purchase a pair of AT-SPEX SFPs from Allied Telesyn they use LC connection like everybody else. They are very new, very cool, and nobody else to my knowledge can match them. Yup I have a pair and they do work, but you didn't hear it from me ;-).
Cheers,
Brian
bbaillie
OOPS, mybad, the 2950 series doesn't support SFPs, you will need a 2940-8TF or go to the 2960 series for the SFP support at minimum. I looked again and you are using 50/125 I tested on 62.5/125. Personally I would contact Allied Telesyn for a demo pair, but then again they are less than $450.00 American each so definitely worth the risk.
Cheers,
Brian
Hi Brian,
Many thanks for this info - certainly keep this handy info for the future.
Cheers.
Mark
