Multiple ADSL Links in Active Mode
acharyr123
Level 3
Level 3
We have 2 Internet Routers with 2 ADSL Ports on individual routers.
Attached n/w diagram will give you an idea of the setup.
The requirement is: all the time 4 ADSL to be used for Internet accessing purpose.
ASA is in single-context mode. On Core switch OSPF is running.
Can someone suggest the necesary changes to be done at gateway level??
paolo bevilacqua
That is not a very simple setup.
I recommend you hire a reputable consultant for the proper configuration.
