MY CISCO 6800 IA CAN NOT JOIN TO THE PARENT
r.barba
Hello
I have a 6807XL with VS-SUP2T-10G, and the 10 Gbps Line Card WS-X6816-10GE, when I tried to provision the join of the 6800IA, I got theses errors.
CORE(config)#interface tengigabitethernet 1/1/1
CORE(config-if)#switchport mode fex-fabric
Command rejected: Mode fex fabric not allowed on non FEX capable slot
CORE(config-if)#channel-group 1 mode on
Command rejected (Port-channel1, Te1/1/1): Cannot be part of bundle, Non FEX Capable Slot
What should be the solution for it??
Rafael Barba
Please rate and mark the post as answered so others can benefit from it.
Reza Sharifi
Does your system meet all the requirement for FEX?
Q.    What are the different components of the Instant Access solution?
A.     The Instant Access solution requires new Cisco Catalyst 6800ia Instant Access clients and Cisco Catalyst 6500 or 6800 Series Switches (Instant Access parents) with Supervisor Engine 2T and WS-X6904-40G-2T line cards. Instant Access requires Cisco Catalyst 6500 or 6800 Series Switches configured for Virtual Switching System (VSS) mode, and we recommended having a pair of switches to provide the maximum level of redundancy and load balancing. Note: In networks where a pair of Cisco Catalyst 6500/6800 is not available, a single Cisco Catalyst 6500/6800 switch may be used when configured for VSS mode.
Link:
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-6800ia-switch/qa_c67-728684.html
Hello
No I don t meet all the requirements, because I have the Line Card WS-X6816-10G-2T instead WS-X6904-40G-2T.
RB
Hi Dear,
I have the same issue but my system meet all required for IA connections with 6807 xl vss switches
but the command: switchport mode fex-fabric is not recognized.
appreciate your urgent support here
thank you.
Eng. Fareed
