02-19-2018 03:01 AM - edited 03-08-2019 01:55 PM
i have configured the firewall to lease dhcp ip, created vlan, qos.
The configuration done on the switch are only
Switch(config)# int gi6
Switch(config-if)#switchport mode access
Switch(config-if)#switchport access vlan 10
But still the Gi6 port shows the old ip of vlan 1 ie: 192.168.100.45, instead it should come as 192.168.10.2
Is there any other configurations necessary to be done in the switch to lease the ip and the pc shall get the ip as 192.168.10.2 of vlan 10.
Please help me.
02-19-2018 03:09 AM
Hi there,
Is the SG300 configured with a SVI in VLAN10? Do you have a DHCP pool for 192.168.100.0/24 ?
cheers,
Seb.
02-19-2018 03:25 AM
port a of firewall is connected to my switch.
So the port a is configured as 192.168.100.0
02-19-2018 04:46 AM
Hi there,
If one switchport on the SG300 is in access mode using VLAN10 and is connected to the firewall port which is providing DHCP leases, and the another switchport (Gi6) is in access mode using VLAN10 and is connected to an enduser device, then you would expect that device to receive a DHCP lease in the 192.168.100.0/24 subnet. Just changing the VLAN Id will not change the subnet.
Please can you provide the running config of the switch.
cheers,
Seb.
02-19-2018 06:13 AM
switch94ae9f#sh run
interface vlan 1
ip address 192.168.100.101 255.255.255.0
no ip address dhcp
interface gigabitethernet1
interface gigabitethernet2
interface gigabitethernet3
interface gigabitethernet4
interface gigabitethernet5
interface gigabitethernet6
interface gigabitethernet7
interface gigabitethernet8
interface gigabitethernet9
interface gigabitethernet10
interface gigabitethernet11
interface gigabitethernet12
interface gigabitethernet13
interface gigabitethernet14
interface gigabitethernet15
interface gigabitethernet16
interface gigabitethernet17
interface gigabitethernet18
interface gigabitethernet19
interface gigabitethernet20
interface gigabitethernet21
interface gigabitethernet22
interface gigabitethernet23
interface gigabitethernet24
interface gigabitethernet25
interface gigabitethernet26
interface gigabitethernet27
interface gigabitethernet28
interface gigabitethernet29
interface gigabitethernet30
interface gigabitethernet31
interface gigabitethernet32
interface gigabitethernet33
interface gigabitethernet34
interface gigabitethernet35
interface gigabitethernet36
interface gigabitethernet37
interface gigabitethernet38
interface gigabitethernet39
interface gigabitethernet40
interface gigabitethernet41
interface gigabitethernet42
interface gigabitethernet43
interface gigabitethernet44
interface gigabitethernet45
interface gigabitethernet46
interface gigabitethernet47
interface gigabitethernet48
exit
02-19-2018 06:42 AM
With the exception of Gi6, all the switchports will be in the default VLAN1. If you connect the firewall to Gi1 and host to Gi2. Providing DHCP and the firewall interface have been correctly configured you should get a DHCP lease in the correct subnet.
cheers,
Seb.
02-19-2018 07:54 AM
So you are saying that there no other additional configurations required for the switch. Actually the port from firewall to switch's port is truncated.
02-20-2018 12:18 AM
OK, if your firewall is adding VLAN tags to the frames leaving its interface, then you will need to configure the SG300 switchport to suit. You can then configure the remaining switchports in access mode in the relevant VLANs.
What is the interface (VLAN) configuration of the firewall interface?
cheers,
Seb.
02-20-2018 01:12 AM
on a side note, your configuration (if the one you posted is the full one) looks very rudimentary. You have no Vlan 10 interface, no routing, no trunk, no dhcp relay enabled anywhere. What does your network look like, are you trunking to a layer 3 device that does the routing ? Is the switch in layer 2 or layer 3 mode ? And last but not least, are you running the latest firmware (1.4.8.06 is the latest) ?
Sorry for all the questions...;)
