N5k and N7k
Not to familiar with the N5k. So here is my issue, I trying to connect n5k via two 10 gig ports to N7k 10 gig ports on a portchannel with truncking as well.
this is only for traffic to pass thru just a uplink. I have two different port channels on both sides. I do not have any ip's attach to the interfaces since I'm doing any routing thru there. But I cannot bring up any of the portchannels or interfaces to become members of the portchannels. This is only a test enviroment. I have included a text config of how it is setup. If anyone see's something wrong or can correct let me know. Any help would be greatful.
OK - I think 2 things:-
1) I would change the portchannel numbers to be the same on both sides (I saw this issue with a pair of 6500's once) so remove all the config and start again using the same port-channel numbers on both sides.
If that does not work - back to basics.
2) Just have 1 cable between the 7k and 5k and just make that a trunk.  If you get the trunk up - then turn it into a port-channel.
Also - have you enabled the LACP feature????
HTH>
7 Replies 7
andrew.prince
Level 10
Level 10
You have a native vlan mis-match - check your 5k config.
Thanks for the reply
Sorry I sent the wrong config please disregard the one above. This is the one that is active now.
N7k Configuration:
interface port-channel102
  description Uplink-N5K-TestSwitch
  switchport
  switchport mode trunk
  switchport trunk native vlan 999
  switchport trunk allowed vlan 102
  spanning-tree port type network
interface Ethernet4/15
  description Uplink-N5k-TestSwitch
  switchport
  channel-group 102 mode active
interface Ethernet4/16
  switchport
  switchport trunk allowed vlan 999
N5K Configuration:
interface port-channel103
  description Uplink-N7k
  switchport trunk allowed vlan 100
interface Ethernet1/3
  channel-group 103 mode active
interface Ethernet1/4
post the output of "show port-channel sum"
Here you go sir. And the portchannel are no shutdown on either side or the interfaces as well. Thanks
N7k
102   Po102(SD)   Eth      LACP      Eth4/15(D)   Eth4/16(D)
N5k
103   Po103(SD)   Eth      LACP      Eth1/3(D)    Eth1/4(D)
HTH>
Yes the LACP feature is on. I will try this out and get back to you. Thanks for the ideas.
Thanks for you help found the solution. It was a fiber issue. Everything is up and running.
