N7k and FEX connections
fsebera
Level 4
Level 4
Once we upgrade our N7k (N7K-1 and N7K-2) to NX-OS 7.2 and insert the F2 series line cards,
will this dual-homed server active-active setup function?
   Server1
   |     |     <----- Server is dual-homed
 FEX-A FEX-B
  /  \ /  \    <----- Each FEX is dual-homed
N7K-1===N7K-2
Thank you
Frank
InayathUlla Sharieff
FEX dual-homing for N7K is now supported as of 7.2 code.
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/7_x/nx-os/release/notes/72_nx-os_release_note.html#pgfId-1125657
Inayath
Yes NX-OS 7.2 supports FEX-AA with F2 series line cards as I pointed out in my original post.
What I am looking for is a server dual connected to 2 different FEX and the 2 FEXs are dual-homed to 2 7000s. Is this supported? What is required?
Frank
It should work fine but I personally havent tested this.
This has been see on the 5K and it used to work fine there.
Where in my question do you see a 5K ?
