N7K/fabricpath/vPC peer link
fab5freddy
Hello
I'm having trouble understanding what the issue is.
I have 2 different networks, each with 2 pairs of N7K's (each using 2 VDC's) with multiple N5K's connected to all N7K's and both the VDC's.
My set-up works fine for one network but not for the other.
The problem is related to the vPC peer link on fabricpath.
I'm running NX-OS  version 6.1(4)
Following is output from my N7K's in the faulty network:
N7K11-ione# show vpc
Legend:
                (*) - local vPC is down, forwarding via vPC peer-link
vPC domain id                     : 2
vPC+ switch id                    : 111
Peer status                       : peer adjacency formed ok
vPC keep-alive status             : peer is alive
vPC fabricpath status             : peer is not reachable through fabricpath
Configuration consistency status  : success
Per-vlan consistency status       : success
Type-2 consistency status         : success
vPC role                          : primary
Number of vPCs configured         : 0
Peer Gateway                      : Disabled
Dual-active excluded VLANs        : -
Graceful Consistency Check        : Enabled
Auto-recovery status              : Enabled (timeout = 240 seconds)
Fabricpath load balancing         : Disabled
Port Channel Limit                : limit to 244
vPC Peer-link status
id   Port   Status Active vlans
1    Po1    up     765
N7k11-ione#
N7K12-ione# show vpc
Legend:
vPC domain id                     : 2
vPC role                          : secondary
1    Po1    up     765
N7K12-ione#
Thanks for the help
Frederic
No Probs.
Happy to hear that. Could you please mark the thread as answered else people think that it is not answered and they have to go through the query. Thanks in advance.
Inayath.
InayathUlla Sharieff
Hi Fedric,
Please check below:
For fabricpath isis adjacency to come up, the peer link needs to be a "P2P" interface not a "broadcast" interface.
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCty44132
Inayath
**********Plz rate if this info is helpfull************
Thank you for the input but this isn't the case in my set-up.
The Po's are configured as P2P, see output:
N7K11-ione# show run all | section "interface port-channel1" | grep medium
  medium p2p
  medium p2p
  medium p2p
N7K12-ione# show run all | section "interface port-channel1" | grep medium
  medium p2p
  medium p2p
  medium p2p
(before doing a grep I had a look at the full config...)
Thank you
Frederic
Hello
Before posting my question I had verified almost everything EXCEPT for fabricpath authentication!
Seems that I made a mistake in copy/pasting my config.
The fabric path authentication was missing on my port-channel used for peering.
But thanks for the input!
Frederic
No Probs.
Inayath.
