07-13-2012 09:32 AM - editado 03-07-2019 07:45 AM
It's a weired issue in N7010, checking is anyone here came across the same?
We did an upgrade from NX-OS 5.1.5 to 5.2.4 and found all M1 line card interfaces were stuck in initializing state for long time.'show module' status says ok. And we cannot execute shut/no shut command under the interface. N7K-M108X2-12L & N7K-M148GT-11 are the two M series cards. Only option was to downgrade back for the time being. Anyone had the same issue and got resolved?
N7K01# sh int e1/1 | in down
Ethernet1/1 is down (initializing)
em 07-13-2012 07:42 PM
I've checked the 5.2 Release Notes and I don't see anything mentioned like what you've experienced.
Can you try running the newer 6.0?
em 07-14-2012 02:29 PM
Already 4 chassis are working fine with the new image and the issue is encountered only in this. The box is in production now. ;(
em 07-15-2012 03:23 PM
Ok then. Try reseating the card.
Descubra e salve suas ideias favoritas. Volte para ver respostas de especialistas, passo a passo, tópicos recentes e muito mais.
Novo por aqui? Comece com estas dicas. Como usar a Comunidade Guia do novo membro
