09-29-2020 02:42 AM
we have enabled L3 routing (BGP) at Nexus9000 93180YC-EX but I cant find any related documentation for the maximum throughput that box can handle or even from the CLI itself
your help is appreciated.
Solved! Go to Solution.
09-29-2020 04:48 AM
From BRKARC-2222
09-29-2020 04:48 AM
From BRKARC-2222
09-30-2020 03:49 AM
Hi Leonid
Many thanks for your support
how can I check the current utilization from the switch itself
09-30-2020 06:42 AM
I think you can't do it. But you don't need it. Because it is non-blocking switch. You will not be able utilize more than it can utilize.
___________________________________________________________________________________
If you like the answer, put an asterisk. If the answer helped solve your problem, approve it as a solution
10-01-2020 02:46 AM
Many thanks for your support, appreciate it
