NAT configuration help (867 Router)
estabueno
Im so close to connecting to the internet, the CD light is solid, the data light is flashing and the router has received an ip from the ISP. I believe I havent configured the NAT correctly so any help would be greatly appreciated. Below is the running config, thanks in advance to any kind souls who are willing to help!
Router#show running-config
Building configuration...
Current configuration : 2065 bytes
! Last configuration change at 00:15:39 UTC Mon Mar 1 1993 by admin
version 15.0
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 10
ip source-route
ip dhcp pool LANDHCPPool
   network 192.168.0.0 255.255.255.0
   default-router 192.168.0.1
   dns-server 208.67.222.222
ip cef
license udi pid CISCO867-K9 sn FGL15042DPJ
username XXXX privilege 15 password 0 XXXXXXXX
ip ssh rsa keypair-name sshkeys
ip ssh version 2
interface ATM0
no ip address
ip flow ingress
load-interval 60
no atm ilmi-keepalive
interface ATM0.1 point-to-point
description adsl point-to-point connection
bandwidth 512
bandwidth receive 6000
ip flow ingress
pvc 0/100
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
description lan
ip address 192.168.0.1 255.255.255.0
interface Dialer0
bandwidth 6000
bandwidth receive 512
ip address negotiated
ip access-group internetinbound in
no ip proxy-arp
ip nbar protocol-discovery
ip flow ingress
ip nat outside
ip virtual-reassembly
encapsulation ppp
load-interval 60
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp pap sent-username XXXXXXXX password 0 XXXXXXXXX
ppp ipcp dns accept
no cdp enable
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list word interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
ip access-list extended LanInbound
permit ip any any
permit icmp any any
access-list 1 permit 192.168.0.0 0.0.0.255
dialer-list 1 protocol ip permit
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
access-class 1 in
exec-timeout 30 0
privilege level 15
login local
transport preferred ssh
transport input ssh
scheduler max-task-time 5000
end
peterace1
What access list is (ip nat inside source list word interface Dialer0 overload) pointing to?
run show ip nat ? to get a list of commands to verity that nat is working
Add "ip nat inside" to Vlan 1 interface. Must be:
interface Vlan1
description lan
ip nat inside
As explained from Peterace1 add an access-list "word" like this:
ip access-list extended word
permit ip 192.168.0.0 0.0.0.255 any
Regards.
