NAT for logical interface
itsupport
Community Member
I've got the following setup
interface GigabitEthernet0/0
description Outside Interface
speed 100
duplex full
nameif outside
security-level 0
ip address (removed) 255.255.255.240
interface GigabitEthernet0/2
description Inside interface
nameif inside
security-level 100
ip address 10.33.1.1 255.255.255.0
interface GigabitEthernet0/2.64
vlan 64
nameif WiFi
security-level 100
ip address 10.33.64.1 255.255.255.0
The inside interface is tunneled to another location & we added the new subnet (10.33.64.0/24) to the cryptomap
Clients on the 64 VLAN can successfully ping across the tunnel & vica versa.
However people on the 64 VLAN cannot access the internet via the outside interface.
I have the following NAT rules:
nat (inside,outside) source static obj_10.33.64.0-24 obj_10.33.64.0-24 destination static BLDCorpNetwork BLDCorpNetwork route-lookup
nat (inside,outside) source static NETWORK_OBJ_10.33.1.0_24 NETWORK_OBJ_10.33.1.0_24 destination static BLDCorpNetwork BLDCorpNetwork no-proxy-arp route-lookup
nat (inside,outside) source static NETWORK_OBJ_10.33.1.0_24 NETWORK_OBJ_10.33.1.0_24 destination static NETWORK_OBJ_10.33.1.0_24 NETWORK_OBJ_10.33.1.0_24 route-lookup
nat (inside,outside) source dynamic any interface
nat (inside,outside) source static any any destination static NETWORK_OBJ_10.11.11.0_24 NETWORK_OBJ_10.11.11.0_24 no-proxy-arp route-lookup
nat (inside,outside) source static any any destination static NETWORK_OBJ_10.11.11.0_29 NETWORK_OBJ_10.11.11.0_29 no-proxy-arp route-lookup
nat (inside,any) source static obj-10.33.1.0 obj-10.33.1.0 destination static obj-10.33.64.0 obj-10.33.64.0 no-proxy-arp
I tried adding the following rule
nat (WiFi,outside) 9 source dynamic any interface
This allows clients on the 64 VLAN to browse the internet, but then they can't send traffic across the tunnel.
I'm thinking I need another NAT rule but can't seem to get it configured correctly.
itsupport
Community Member
I was able to get it working with the following via NAT Exemption.
nat (WiFi,outside) source static obj_10.33.64.0-24 obj_10.33.64.0-24 destination static BLDCorpNetwork BLDCorpNetwork no-proxy-arp
nat (WiFi,outside) source dynamic any interface
