NAT Multicast
JonnyNet
I am trying to permit a multicast video stream to operate over an alternative IP address (239.239.20.5) as per the requirement from one customer without changing the origin multicast IP that all other customers use (239.239.10.5).
In my LAB I have 3 Routers (see attached topology diagram), one is the multicast source, the other the multicast destination, and the one in the middle running PIM, and everything works fine. If however on the middle router (R2), I add either of the below lines or both I am unable to get the multicast to work with the translated IP. It does however continue to work with the original IP Address.
ip nat inside source static 239.239.20.5 239.239.10.5 extendable
ip nat outside source static 239.239.10.5 239.239.20.5 extendable
(with ip nat inside and ip nat outside on the interfaces)
My general question is, is something special required to make the cisco router NAT multicast IP Addresses?
Below is the configuration of the routers and the output of the multicast routing table on the 3 routers when I attempt the multicast traffic:
R1
interface Ethernet0/1
 ip address 192.168.1.2 255.255.255.0
 ip pim sparse-dense-mode
interface Loopback1
 ip address 192.168.2.1 255.255.255.0
 ip igmp join-group 239.239.20.5
router rip
 version 2
 network 192.168.0.0
 network 192.168.1.0
 network 192.168.2.0
 no auto-summary
sh ip mroute
IP Multicast Routing Table
Flags: D - Dense, S - Sparse, B - Bidir Group, s - SSM Group, C - Connected,
       L - Local, P - Pruned, R - RP-bit set, F - Register flag,
       T - SPT-bit set, J - Join SPT, M - MSDP created entry, E - Extranet,
       X - Proxy Join Timer Running, A - Candidate for MSDP Advertisement,
       U - URD, I - Received Source Specific Host Report,
       Z - Multicast Tunnel, z - MDT-data group sender,
       Y - Joined MDT-data group, y - Sending to MDT-data group,
       G - Received BGP C-Mroute, g - Sent BGP C-Mroute,
       N - Received BGP Shared-Tree Prune, n - BGP C-Mroute suppressed,
       Q - Received BGP S-A Route, q - Sent BGP S-A Route,
       V - RD & Vector, v - Vector, p - PIM Joins on route,
       x - VxLAN group
Outgoing interface flags: H - Hardware switched, A - Assert winner, p - PIM Join
 Timers: Uptime/Expires
 Interface state: Interface, Next-Hop or VCD, State/Mode
(*, 239.239.20.5), 00:18:37/00:02:23, RP 0.0.0.0, flags: DCL
  Incoming interface: Null, RPF nbr 0.0.0.0
  Outgoing interface list:
    Ethernet0/1, Forward/Sparse-Dense, 00:18:37/stopped
    Loopback1, Forward/Sparse-Dense, 00:18:37/stopped
(*, 224.0.1.40), 00:18:37/00:02:23, RP 0.0.0.0, flags: DCL
R2
interface Ethernet0/0
 ip address 192.168.0.2 255.255.255.0
 ip nat outside
 ip virtual-reassembly in
 ip nat inside
interface Loopback1
 ip address 192.168.3.1 255.255.255.0
router rip
 version 2
 network 192.168.0.0
 network 192.168.1.0
 network 192.168.3.0
 no auto-summary
sh ip mroute
       x - VxLAN group
(*, 239.239.10.5), 00:00:04/stopped, RP 0.0.0.0, flags: D
    Ethernet0/1, Forward/Sparse-Dense, 00:00:04/stopped
    Ethernet0/0, Forward/Sparse-Dense, 00:00:04/stopped
(192.168.4.1, 239.239.10.5), 00:00:04/00:02:54, flags: PT
  Incoming interface: Ethernet0/0, RPF nbr 192.168.0.1
    Ethernet0/1, Prune/Sparse-Dense, 00:00:04/00:02:54
(*, 224.0.1.40), 00:07:10/00:02:50, RP 0.0.0.0, flags: DCL
    Ethernet0/0, Forward/Sparse-Dense, 00:06:41/stopped
    Ethernet0/1, Forward/Sparse-Dense, 00:06:41/stopped
    Loopback1, Forward/Sparse-Dense, 00:07:10/stopped
R3
 ip address 192.168.0.1 255.255.255.0
interface Loopback1
 ip address 192.168.4.1 255.255.255.0
router rip
 version 2
 network 192.168.0.0
 network 192.168.1.0
 network 192.168.4.0
 no auto-summary
sh ip mroute
       x - VxLAN group
(*, 239.239.10.5), 00:00:03/stopped, RP 0.0.0.0, flags: D
    Ethernet0/0, Forward/Sparse-Dense, 00:00:03/stopped
(192.168.4.1, 239.239.10.5), 00:00:03/00:02:56, flags: PT
  Incoming interface: Loopback1, RPF nbr 0.0.0.0
    Ethernet0/0, Prune/Sparse-Dense, 00:00:03/00:02:56
(*, 224.0.1.40), 00:18:58/00:02:01, RP 0.0.0.0, flags: DCL
    Ethernet0/0, Forward/Sparse-Dense, 00:18:29/stopped
    Loopback1, Forward/Sparse-Dense, 00:18:58/stopped
 TEST FROM R3
#ping 239.239.10.5 so lo1
(because of the static NAT I an hoping the 239.239.20.5 join group on R1 would reply. If I change the join group back to the original IP of 239.239.10.5 so there is no NAT, then the ping works fine)
Hi Jonathan,
I do not think you can do NAT for the multicast address. You can do NAT for the multicast source address when it is operating on a private IP and you have receivers outside of your network. Please look at the following Cisco documentation:- https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ipaddr_nat/configuration/xe-16/nat-xe-16-book/iadnat-multicast-dynamic.html
Here is part of the document I grab for you regarding "Restrictions for IP Multicast Dynamic NAT":-
The IP Multicast Dynamic NAT feature does not support:
- IPv4-to-IPv6 address translation.
- Multicast destination address translation.
- Port Address Translation (PAT) overloading for multicast.
- Source and destination address translation.
- Unicast-to-multicast address translation.
Please correct me if I am wrong.
HTH,
Meheretab
HTH,
Meheretab
