Greetings All
I have a DSL Modem (sets in bridge mode)---Cisco 881 Router---Samsung camera (192.168.2.52)
I need to forward ports of Camera , do pasted configuration
ip nat inside source static tcp 192.168.2.52 943 interface FastEthernet4 943
ip nat inside source static udp 192.168.2.52 943 interface FastEthernet4 943
ip nat inside source static tcp 192.168.2.52 53 interface FastEthernet4 53
ip nat inside source static tcp 192.168.2.52 554 interface FastEthernet4 554
ip nat inside source static tcp 192.168.2.52 4520 interface FastEthernet4 4520
ip nat inside source static tcp 192.168.2.52 80 interface FastEthernet4 80
but when i am accessing it from outside ,it is not showing means interface of Camera is not showing
while checking port scan status on mxtoolbox.com
KCT-ROUTER#show ip nat translations | i 192.168.2.52
tcp 212.76.65.198:53 192.168.2.52:53 --- ---
tcp 212.76.65.198:80 192.168.2.52:80 --- ---
tcp 212.76.65.198:554 192.168.2.52:554 --- ---
tcp 212.76.65.198:943 192.168.2.52:943 --- ---
udp 212.76.65.198:943 192.168.2.52:943 --- ---
udp 212.76.65.198:1028 192.168.2.52:1028 168.126.63.1:53 168.126.63.1:53
tcp 212.76.65.198:4520 192.168.2.52:4520 --- ---
Interface Configuration
ip address 212.76.65.198 255.255.255.252
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
pppoe-client dial-pool-number 1
Routing and NAT
ip nat inside source list 1 interface FastEthernet4 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
access-list 1 permit any
kindly advice.
