NAT question
royalblues
Level 10
Level 10
Hi all
I have a strange NAT situation
My router fastethernet IP is 172.16.24.1/22
I want to PAT 172.16.25.0, 26.0 & 27.0 to 172.16.24.2
Can this be done as the netmask length overlaps
Narayan
Apologies. I've tested the config with 22 & /24 and there is no issue, the router will accept either. This is with an up/up interface configured with a /22 as in your case.
(see below extract from CCO).
netmask - Network mask that indicates which address bits belong to the network and subnetwork fields and which bits belong to the host field. Specify the netmask of the network to which the pool addresses belong.
7 Replies 7
spremkumar
Level 9
Level 9
Is that ip configured on any of the interfaces of your router ?
regds
it is not configured on any of the interfaces but since i would be doing this on a production router just wanted to make sure
Narayan
mark.edwards
yes it can be done.
ip nat pool TEST 172.16.24.2 172.16.24.2 netmask 255.255.255.0
ip nat inside source list 10 pool TEST overload
access-list 10 permit 172.16.25.0 0.0.0.255
access-list 10 permit 172.16.26.0 0.0.0.255
access-list 10 permit 172.16.27.0 0.0.0.255
Mark
thanks for the reply, but i know the configurations
what i wanted to know was since the netmask would be a /22 subnet and the pool falls within this range, whether the router accepts it.
Narayan
Thanks Mark.
Let me configure the same on my router.
Will revert back once done
I used the /24 netmask and it worked
Thanks everyone
Narayan
