NAT using loopback interface
kenneth-goh
I have a requirement as shown in the diagram. When R1ping to loopback0 on R2 and R3 will reply to the ping.
I am not allow to change the ip nat inside (on Fa0/0) and ip nat outside (on Fa1/0) on R2. Thanks in advanced.
Julio E. Moisa
If you want to use the R2's loopback to translate your R1's LANs try with
R2
ip access-list standard MY-NETS
permit 192.168.0.0 0.0.0.255  <-- example R1's LAN
interface loopback 0
ip address 10.247.254.56 255.255.255.255
int fa0/0
description P2P-R1
ip nat inside
interface f1/0
description TO-R2-R3
ip nat outside
ip nat inside source list MY-NETS interface loopback 0 overload
ip route 0.0.0.0 0.0.0.0 fa1/0 name INTERNET   <--- Example
R3 & R4
configure:
ip route 10.247.254.56 255.255.255.255 10.245.16.1
Now you can verify the translations on R2 using a debug: debug ip nat or using show ip nat translations.
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
On R1
R1# ping 10.247.254.56 <-- R2's loopback is not translating to R3's 10.245.16.20
On R2
interface Loopback1
interface FastEthernet0/0
 ip address 10.250.21.21 255.255.255.0
 ip nat inside
 ip virtual-reassembly
interface FastEthernet1/0
 ip address 10.245.16.1 255.255.255.0
 ip nat outside
ip nat inside source list NAT interface Loopback1 overload
ip access-list standard NAT
 permit 10.250.21.20
