10-04-2011 03:51 AM - edited 03-07-2019 02:35 AM
Can somebody say me that numbers 3281, 3068 are fine for the port 3/1 Error RX?
sh top
Start Time: Oct 04 2011 10:41:18
End Time: Oct 04 2011 10:41:49
Port Band- Uti Bytes Pkts Bcst Mcst Error Over
width % (Tx + Rx) (Tx + Rx) (Tx + Rx) (Tx + Rx) (Rx) flow
3/1 100 2 20288563 22101 58 155 3281 0
3/2 100 2 20175489 18429 55 156 0 0
3/3 100 1 12524163 20932 64 313 0 0
sh top
Start Time: Oct 04 2011 10:47:47
End Time: Oct 04 2011 10:48:17
PortType: all
Metric: util
3/1 100 2 18959430 20774 108 147 3068 0
3/2 100 2 18837255 17274 108 149 0 0
3/3 100 1 8325442 16661 116 299 0 0
Solved! Go to Solution.
10-04-2011 05:27 AM
You have a counter for total packets (TX + RX) and a counter for packets received with error. It would be nice if there were a counter that gave total received packets so that you could calculate what percentage of receive packets are with error. But we do not have that counter. So calculate the percentage of total packets that are received in error. When I do the calculation it looks like almost 15% of total packets are packets received with error. To me that is a high percentage and I am not sure that I would say that it was ok.
Rick
10-04-2011 04:20 AM
Which numbers do I have to compare. Not sure about Error RX field and others
10-04-2011 05:17 AM
Any expert in CatOS?
10-04-2011 05:27 AM
Rick
