Need advice on the HWIC-4ESW-POE
shikamarunara
Level 4
Level 4
I just purchased a HWIC-4ESW-POE for a 2811 router and realized that I also need get a different power supply for it as well. Is this power supply easy to install? Will I need anything else besides the 2811, the HWIC-4ESW-POE, the power supply PWR-2811-AC-IP, and the right IOS?
- Shikamaru
Collin Clark
The power supply is easy to install. There is a modular plug to disconnect and one screw if I remember right. You may also need PVDM's.
Hope that helps.
Thanks, Collin. One more question; besides the new power supply, there's no change at all to the power requirements of the router? It still plugs into standard power?
-Shikamaru
Yes that is correct, no change in power requirements.
