need advice to build my own CCNP Lab at Home
Cisco_Learner25
Hi Seniors,
I'm thinking to build my own lab for CCNP practice at home. Could you please tell me that which series of routers and switches I need. And how many routers and how many switches I need, to do my CCNP route and switch practice. I have done my CCNA, with the help of Packet tracer. But now I'm thinking to have some real lab.
So to build my own lab, I need your advices. That which cheapest price combination can make my CCNP home lab. There are many routers and switches are available at ebay, but I don't know the differences between the models of routers and switches. Why they are different than other? what problem I can have, if i will buy some router, which I should not buy etc. Because I'm looking for some cheap combination by price, and I can buy some wrong router or switch, which I should not buy, when I want to do the practice of CCNP. So that’s why I need your advice guys.
Please guide me.
5 Replies 5
dennicla
Hello Omer,
I studied for and passed my NP via GNS3.  Here are some sites to look at and into.
https://community.gns3.com/welcome
https://github.com/GNS3/gns3-gui/releases
https://community.gns3.com/docs/DOC-1708
https://community.gns3.com/community/software/documentation
Look on YouTube as well for any setup instructions if you get stuck.
Hi Dennicla,
Thank you for the reply. I have tried with GNS3, but I want to see real devices, where to put console cable, how does real devices works, etc.
Hello
if you can afford it go for hardware - virtualization/simulators etc is a good cheap solution however in my opinion you cannot get any better than studying on the real thing, These virtualization/simulators can be buggy and not produce the correct results and this then can make you wary if the results your seeing is actually correct..
I would say to get you going and be applicable for further advanced studies such as CCIE
1 x 2500 terminal server (8/16 pin out CAB-OCTAL-ASYNC cable)
2 - 4x 3560 -24ts
2- 4 x 2811  (256mb flash/128mb memory - running c2800nm-adventerprisek9-mz.151-4.or above)
Ethernet cabling /kettle leads and power surge protectors etc...
res
Paul
Kind Regards
Paul
Hi Paul,
Thank you for your reply.
Could you please explain your wording more in detail?
2 - 4x 3560 -24ts
I did not understand this text. Could you please explain me a bit?
regards
Hello
These are the devices I recommended to use for a physical  CCNP lab.
Ebay is the best place to look for them
res
Paul
Kind Regards
Paul
