Need Advice
shimabuku
I met a friend a few days ago who is leasing space in a few buildings. The space came with Cisco equipment and is currently in use. I drew a diagram in Visio the best I could and was looking for advice regarding this current topology. He has two ISP's but is currently using only one. There are two extra 2621xm's and 6 WS-C3508G-XL. I was thinking of using one of the extra 2621xm's and doing HSRP between the 2911. If you take a look at the diagram there are a bunch of WS-C3550-48 switches hanging off the C2970G switch. Unfortunately there are no layer 3 switches. How would you layout this particular diagram given the two extra 2621xm's and six WS-C3508G-XL?
Reza Sharifi
Looking at your diagram, you can keep all the switches as layer-2 only and have 2 routers (one 2911 and one 2621xm) as the default gateway for all host and run HSRP between the 2 routers.
