06-04-2013 07:35 AM - edited 03-07-2019 01:43 PM
continue
how can now configure dhcp server on core such that when request come to core it should tranfer to dhcp server from any of tc he two vlan ,is there any extra command which we need to congfigure on core switch to request dhcp server for ip add,please some one help me.
configuration of the core switch i am attaching below
SCE-CORE#sho run
Building configuration...
Current configuration : 5714 bytes
! Last configuration change at 06:48:40 UTC Tue Jun 4 2013
version 15.1
no service pad
service compress-config
hostname SCE-CORE
boot-start-marker
boot system flash bootflash:cat4500e-universal.SPA.03.04.00.SG.151-2.SG.bin
boot-end-marker
vrf definition mgmtVrf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
enable secret 4 tnhtc92DXBhelxjYk8LWJrPV36S2i4ntXrpb4RFmfqY
username admin privilege 15 password 0 cisco
no aaa new-model
hw-module uplink select tengigabitethernet
ip vrf Liin-vrf
ipv6 multicast rpf use-bgp
vtp mode transparent
power redundancy-mode redundant
spanning-tree mode pvst
redundancy
mode sso
vlan internal allocation policy ascending
vlan 50
name SERVER
vlan 51
name USERS
interface Port-channel1
switchport
interface Port-channel2
switchport
interface Port-channel3
switchport
interface Port-channel4
switchport
interface FastEthernet1
vrf forwarding mgmtVrf
no ip address
speed auto
duplex auto
interface GigabitEthernet1/1
switchport mode trunk
channel-group 1 mode on
interface GigabitEthernet1/2
interface GigabitEthernet1/3
interface GigabitEthernet1/4
interface GigabitEthernet1/5
channel-group 2 mode on
interface GigabitEthernet1/6
interface GigabitEthernet1/7
interface GigabitEthernet1/8
interface GigabitEthernet1/9
channel-group 3 mode on
interface GigabitEthernet1/10
interface GigabitEthernet1/11
interface GigabitEthernet1/12
interface GigabitEthernet1/13
channel-group 4 mode on
interface GigabitEthernet1/14
interface GigabitEthernet1/15
interface GigabitEthernet1/16
interface GigabitEthernet1/17
interface GigabitEthernet1/18
interface GigabitEthernet1/19
interface GigabitEthernet1/20
interface GigabitEthernet1/21
interface GigabitEthernet1/22
interface GigabitEthernet1/23
interface GigabitEthernet1/24
interface GigabitEthernet1/25
interface GigabitEthernet1/26
interface GigabitEthernet1/27
interface GigabitEthernet1/28
interface GigabitEthernet1/29
interface GigabitEthernet1/30
interface GigabitEthernet1/31
interface GigabitEthernet1/32
interface GigabitEthernet1/33
interface GigabitEthernet1/34
interface GigabitEthernet1/35
interface GigabitEthernet1/36
interface GigabitEthernet1/37
interface GigabitEthernet1/38
interface GigabitEthernet1/39
interface GigabitEthernet1/40
interface GigabitEthernet1/41
interface GigabitEthernet1/42
interface GigabitEthernet1/43
interface GigabitEthernet1/44
interface GigabitEthernet1/45
interface GigabitEthernet1/46
interface GigabitEthernet1/47
interface GigabitEthernet1/48
interface GigabitEthernet2/1
interface GigabitEthernet2/2
interface GigabitEthernet2/3
interface GigabitEthernet2/4
interface GigabitEthernet2/5
interface GigabitEthernet2/6
interface GigabitEthernet2/7
interface GigabitEthernet2/8
interface GigabitEthernet2/9
interface GigabitEthernet2/10
interface GigabitEthernet2/11
interface GigabitEthernet2/12
interface GigabitEthernet2/13
interface GigabitEthernet2/14
interface GigabitEthernet2/15
interface GigabitEthernet2/16
interface GigabitEthernet2/17
interface GigabitEthernet2/18
interface GigabitEthernet2/19
interface GigabitEthernet2/20
interface GigabitEthernet2/21
interface GigabitEthernet2/22
interface GigabitEthernet2/23
interface GigabitEthernet2/24
interface GigabitEthernet2/25
interface GigabitEthernet2/26
interface GigabitEthernet2/27
interface GigabitEthernet2/28
interface GigabitEthernet2/29
interface GigabitEthernet2/30
interface GigabitEthernet2/31
interface GigabitEthernet2/32
interface GigabitEthernet2/33
interface GigabitEthernet2/34
interface GigabitEthernet2/35
interface GigabitEthernet2/36
interface GigabitEthernet2/37
interface GigabitEthernet2/38
interface GigabitEthernet2/39
interface GigabitEthernet2/40
interface GigabitEthernet2/41
interface GigabitEthernet2/42
interface GigabitEthernet2/43
interface GigabitEthernet2/44
interface GigabitEthernet2/45
interface GigabitEthernet2/46
interface GigabitEthernet2/47
interface GigabitEthernet2/48
interface TenGigabitEthernet3/1
interface TenGigabitEthernet3/2
interface GigabitEthernet3/3
interface GigabitEthernet3/4
interface GigabitEthernet3/5
interface GigabitEthernet3/6
interface TenGigabitEthernet4/1
interface TenGigabitEthernet4/2
interface GigabitEthernet4/3
interface GigabitEthernet4/4
interface GigabitEthernet4/5
interface GigabitEthernet4/6
interface Vlan1
no ip address
interface Vlan50
description "SERVER VLAN"
ip address 192.168.50.1 255.255.255.0
interface Vlan51
description "USERS VLAN"
ip address 192.168.51.1 255.255.255.0
no ip http server
banner motd ^CTHIS IS SAUDI COUNCIL OF ENG CORE ^C
line con 0
stopbits 1
line vty 0 4
login
end
SCE-CORE#
06-04-2013 01:14 PM
Go to each interface of VLAN
(config)# int vlan 50
(config-if)#ip helper-address 192.168.50.2
(config)# int vlan 51
06-04-2013 09:03 PM
thnks for help but i have one doubt my network scenario is some what like this
i have 1 core 4507 and 4 layer 2 switch , each of four uplink from each switch is moving toward core switch , this uplinks are made as ether channel.
MY DHCP SERVER is connected on my L2 switch and i am having my svi vlan configure on my CORE SWITCH , that is vlan 50 and 51
so core switch is this possible if just i give on ip helper-address in the svi and the pc on the layer 2 switch get ip add from the server and or i need to connect dhcp server in the core switch i have this doubt can any one help me please
06-04-2013 09:45 PM
clients should be able to reach the dhcp server if its connected to the L2 switch , same for the servers
