Need help in configuring a 4500 switch for VLANs and a two 3845 routers
m-abooali
Level 4
Level 4
I have a Cisco 4500 Switch as core switch where all the users will be conecting to and there will be two 3845 routers facing a datacenter.
I need to have three VLANs:
VLAN1 for managemnet
VLAN2 internal Office
VLAN3 External Office
and have this switch talk to these routers. Then I need to setup (all static) HSRP between the two routers for redundancy.
I would appreciate if you guys can help me with the configuration of these VLANs. all on the switch? do I need subinterfaces? I have enough physical ether interfaces on the routers.
since it is only pone switch as core and everthing else, collapse, then I assume i don't need subInterfaces on the router. I am confused on how to defined the trunck or truncks in this case.
Your input is highly apprecitaed.
Mike
15 Replies 15
Thanks very much John.
Masood
