Need help to debug ccm between a cisco and alcatel device
rvijayananth
Beginner
Beginner
I would like to form a ethcfm - ccm session between two devices,one is an Alcatel IPD router and another is a 7600 router,both of them connected by a 1Gig ethernet connection.
I have configured the below configuration in Alcatel IPD box,
config set on alcatel
provider domain of level 7
assocation 1
vlan 2000
local mep 100
remote mep 200
Original configuration on alcatel
domain 6 name "domaincisco" level 7
            association 1 format vid name "2000"
                bridge-identifier 2000
                exit
                remote-mepid 200
            exit
        exit
sap ntio-1:sfp:2:2000 create
                eth-cfm
                    mep 100 domain 6 association 1 direction down
                        ccm-enable
                        low-priority-defect allDef
                        no shutdown
                    exit
                exit
            exit
            no shutdown
I need to configure a corresponding configuration in my cisco device.Below is the configuration which I tried and is not working though.Please help me correct it on my cisco side.
config set on cisco
assocation 1
vlan 2000
local mep 200
remote mep 100
Original configuration on cisco
CISCO-7606R#show version
Cisco IOS Software, c7600s72033_rp Software (c7600s72033_rp-ADVIPSERVICES-M), Version 12.2(33)SRD4, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Mon 22-Feb-10 04:44 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)SX5, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, c7600s72033_rp Software (c7600s72033_rp-ADVIPSERVICES-M), Version 12.2(33)SRD4, RELEASE SOFTWARE (fc2)
CISCO-7606R#show running-config interface g1/10
Building configuration...
Current configuration : 155 bytes
interface GigabitEthernet1/10
switchport
switchport mode trunk
ethernet cfm mep level 7 mpid 200 vlan 2000
end
CISCO-7606R#
*Oct 23 08:07:12.790: CFM-PKT: Skipped sending CC for MEP mpid 200 - VLAN 2000 not configured globally.conf
CISCO-7606R#
CISCO-7606R#
CISCO-7606R#
ethernet cfm domain provider level 7
mep archive-hold-time 30
service 2000 vlan 2000
ethernet cfm enable
ethernet cfm cc enable level 7 vlan 2000
ethernet cfm cc level 7 vlan 2000 interval 10 loss-threshold 3
nicholas_ong
Beginner
Beginner
I am experiencing similar issue when configuring on ME3800X with a BTI device.
How should I configure the Cisco ME switch such that CFM works between both devices?
Recognize Your Peers
