Need Help! Vlan problem
shuangufl
I set up three vlans on 3560 switch(using command:switchport access vlan #) But when I connect my PC to any port assigned to those vlans including vlan1(default), my PC cannot obtain the IP address automaticlly. How can I solve this problem? Many thanks!
5 Replies 5
mohammedmahmoud
Level 11
Level 11
In which VLAN does the DHCP server reside ?
BR,
Mohammed Mahmoud.
VLAN1(the default one)
chris.lepa
(config)#int vlan
(config-if)#ip helper-address
Hope that helps.
-Chris
hi,
make sure that your server is reachable and if there is any snooping configured on your switch.
could you post the config of your switch will help better
thanks
Current configuration : 3202 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Switch
no aaa new-model
ip subnet-zero
ip routing
ip multicast-routing distributed
ip igmp snooping vlan 1 static 239.1.1.14 interface Fa0/4
ip igmp snooping vlan 1 static 239.1.1.14 interface Fa0/6
ip igmp snooping vlan 1 static 239.1.1.13 interface Fa0/3
ip igmp snooping vlan 1 static 239.1.1.13 interface Fa0/6
ip igmp snooping vlan 1 static 239.1.1.12 interface Fa0/2
ip igmp snooping vlan 1 static 239.1.1.12 interface Fa0/6
ip igmp snooping vlan 1 static 239.1.1.11 interface Fa0/1
ip igmp snooping vlan 1 static 239.1.1.11 interface Fa0/6
ip igmp snooping vlan 3 static 239.1.1.15 interface Fa0/15
ip igmp snooping vlan 3 static 239.1.1.15 interface Fa0/17
ip igmp snooping vlan 3 static 239.1.1.18 interface Fa0/17
ip igmp snooping vlan 3 static 239.1.1.17 interface Fa0/15
ip igmp snooping vlan 3 static 239.1.1.17 interface Fa0/17
ip igmp snooping vlan 3 static 239.1.1.16 interface Fa0/15
ip igmp snooping vlan 3 static 239.1.1.16 interface Fa0/17
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0/1
switchport mode access
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
switchport access vlan 3
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
no switchport
no ip address
interface FastEthernet0/15
ip access-group 1 in
interface FastEthernet0/16
no switchport
no ip address
interface FastEthernet0/17
interface FastEthernet0/18
switchport access vlan 4
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
no ip address
interface Vlan2
no ip address
no ip mroute-cache
interface Vlan3
no ip address
interface Vlan4
no ip address
ip classless
ip route 192.168.10.34 255.255.255.255 FastEthernet0/14
ip route 192.168.10.40 255.255.255.255 FastEthernet0/16
ip http server
access-list 1 deny any
control-plane
line con 0
line vty 0 4
login
line vty 5 15
login
end
Thanks a lot!
