Shyam,
In summary
Suppervisor EngineManages 6500 switch, modules installed , VLAN management etc.. usually runs CatOS code.
MSFC, MSFC2 Routing engine or router , a doughter card installed in Sup engine. Runs IOS code.
PFC or PFC2 Policy Feature Card - another doughter card Installed in Sup engine,
QoS functionality resides on the PFC and is a requirement for Layer 3 or Layer 4 QoS processing.
6500 Backplain Refers to 6500 Chassis BUS Fabric architecture
Ethernet Modules Ethernet cards installed in 6500 switch slots, 48 10/100/1000 Base-T
To install two sups in a single chassis is to provide L2/L3 redundancy failover, both need to be same model, same sup type , same IOS code for highavailability.
Here is all the information you need
http://www.cisco.com/en/US/products/hw/switches/ps708/products_data_sheets_list.html
Q&A on 6500 series
http://www.cisco.com/en/US/products/hw/switches/ps708/prod_qandas_list.html
Jorge
Pls rate any helpful posts !
Jorge Rodriguez
