Need more SF port
CSCO11657467
Beginner
Beginner
I have cisco switch ws-2960 s fps-L... that contain 48 port Gigabit ethernet and 4 spf
spremkumar
Engager
Engager
Even 3750 model switches comes up with the same config of both 48*1G ports + 4 SFPs, if you shed more light on what is your exact requirement with a small background about your setup will help to get more suggestions from other experts as well.
regds
Hi spremkumar
my switch have only 4 sfp.. i need 5 sfp to connect to access switch.. one of the engineer  suggest me to convert 1g ethernet port to sfp ..
Thanks ..
Than,
2960's only have 4 SFP's. To have SFP's more than 4 number, you have to :
1. Use another switch like 3750 with 12 SFP ports.
2. If this switch is a 2960-S switch, you can use a stacking module and stack another 2960 switch to have more SFP Ports.
3. As mentioned by your colleague, you can use a Copper to fiber converter to achieve the same.
http://www.dlink.co.in/products/?pid=248
HTH,
-amit singh
Recognize Your Peers
