01-16-2011 05:31 PM - edited 03-06-2019 03:01 PM
I have cisco switch ws-2960 s fps-L... that contain 48 port Gigabit ethernet and 4 sfp pot.. but i need 5 sfp prot to connect to Access layer switch with fiber connection ... i have only 4 port.. so what should i do ..
Pls help me
Solved! Go to Solution.
01-16-2011 06:23 PM
For just one port, you can use an interface converter.
01-16-2011 06:17 PM
Hi Than,
Only way out is to move to a switch which has more than 4 SFP ports or to stack another 2960 switch with the switch you have.
Shashank
Please rate if this answered your question
01-16-2011 06:55 PM
Hi shashank
Thanks for your help
01-16-2011 06:23 PM
01-16-2011 06:56 PM
Hi paolo
Thanks for your suggestion..
