Need SFP and cabling assistance to connect C9200L-48P-4G(Gi1/1/1-4) and WS-C2960S-48FPD-L(Te4/0/1-4)
pratikpatel18
Hi Cisco Community,
I want to connect 1G Switch to 10G Switch . Can you please let me know what kind of cable and SFP will require at both end?
Uplink Switch :  C9200L-48P-4G with 1G capability
Access Switch : WS-C2960S-48FPD-L with 10G capability
Pratik Patel
balaji.bandi
8 Replies 8
balaji.bandi
Depends on distance, you should go with SFP 1GB both the side  MMF
https://www.cisco.com/c/en/us/products/collateral/interfaces-modules/gigabit-ethernet-gbic-sfp-modules/datasheet-c78-366584.html
BB
Thank you Balaji for reply,
My both switches are on different floor and we are using patch panel to connect floors. Can you please suggest cable type I should use ?
Pratik Patel
Leo Laohoo
Not going to work:  Both ends must use optics with the same speed.  It is either SFP at both ends or SFP+ at both ends and not a mix of SFP and SFP+.
Hi Leo,
I am going to use 1G SFP at both end with MMF fiber, please let me know if you think it still won't work.
Pratik
What are the exact models/SKU of the optics used?
Hi Leo,
Please find the SFP and Cable details below:
SFP type1000Base-SX
Cable Type:  LC to LC Fiber  10Gb Multimode(MMF) OM3 Duplex 50/125 3-Meter (10ft), for Gigabit Ethernet 1000Base-SX
Pratik Patel
That will work.
Thank you Leo,
Pratik
