09-22-2020 07:10 AM
Hello, I have got this reset reason from the Nexus, how could I find the problem or mitigate it?
Device name: SW01_ABC
bootflash: 240834904 kB
Kernel uptime is 0 day(s), 45 hour(s), 26 minute(s), 54 second(s)
Last reset at 348680 usecs after Mon Sep 20 11:15:52 2020
Reason: Watchdog Timeout
System version: 7.0(3)I7(3)
Service:
thanks a lot,
09-22-2020 08:27 AM
Not sure if this is the root cause, but there is a bug associated with the 9k regarding watchdog timeout.
Have a look:
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvg71131/?rfs=iqvred
09-22-2020 06:16 PM
Hi Alejandro,
A system reset caused by a watchdog timeout can have multiple different root causes. If possible, I highly recommend opening up a support case with Cisco TAC so that we can investigate this issue further and provide an accurate root cause, as this will require in-depth log analysis.
Thank you!
-Christopher
