Netflow Configuration Issue
everestm
Hello All,
I'm trying to configure netflow on my 6509. It works and exports data for layer 3 interfaces fine.
I'm trying to monitor layer 2 interfaces (both access and trunk). Is this possible?
In some locations I've seen reference to the commands
ip flow ingress layer2-switched vlan <vlanlist>
ip flow export layer2-switched vlan <vlanlist>
however when I try to put the commands in at global config they are rejected. ("ip flow" is rejected).
Is this possible, am I doing something wrong?
6509/Sup 720/3BXL
12.2(18)SXF8
7 Replies 7
Jan Nejman
Level 3
Level 3
Try to configure: mls nde
It enable layer 2 accounting...
layer2-switched vlan comman activates sending information about communication in the same vlan, i.e. from port 1 in vlan A to port 2 in swame vlan A. More about layer2-switched commands you can find on our web page: http://support.caligare.com/kb/7
More info abou mls nde configuration can be found on the url: http://netflow.caligare.com/configuration_native.htm
Bye
Jan
Thanks for the reply's
The above sites just mention using the
commands ... which unfortunatly my 6509 won't take. Has anyone else run into a switch rejecting the commands? From what I can tell with my IOS and the 3BXL, I should be fine, it just doesn't work.
I have the same problem did anyone have a solution?
could you send me exact error message when you try "ip flow" commands? Why it is rejected?
Do you using NAT on the box? What is mls flow mask setting?
Kind regards,
Jan
dannyf
Command rejected, it does not even parse, I have the right hardware version 3B (6509 sup720-3B)and supported IOS version 12.2(33)SXH2a.
any ip flow xxx commands are not allowed only the ip flow-xxxx commands work.
ip flow-cache timeout active 1
ip multicast-routing
no ip domain-lookup
no ipv6 mld snooping
ipv6 mfib hardware-switching replication-mode ingress
no mls acl tcam share-global
mls aging long 128
mls aging normal 32
mls netflow interface
mls flow ip interface-full
no mls flow ipv6
mls nde sender version 5
mls qos
mls cef error action freeze
ip flow-export source Loopback0
ip flow-export version 5
ip flow-export destination x.x.x.x 2055
I tried version 12.2(18)SXF14 and there is not problem with SUP720-3B.
See:
Lan2(config)#ip flow ingress layer2-switched vlan 100 ?
, comma
- hyphen
Maybe the problem is in the IOS version... I saw several problems with mls flow mask when I used NAT/PAT. But the problem with "ip flow" command I have never seen in the past. I'll more investigate in to this problem or try contact your engeneer from Cisco. I've no idea why the command is not supported at this time.
Jan
