06-14-2019 10:08 AM
I'm unable to use the netflow "sh ip flow top-talkers"
I have the message "% Cache is empty"
I configured :
ip flow-top-talkers
top 10
sort by bytes
On all interfaces (and SVI) ip flow ingress
CEF is running on all interfaces and also on my SVI.
The switch is in "ip routing" mode.
I'm able to collecte netflow flow with Solarwinds. It works.
But unable to use "top-talkers"
However top-talkers is in the feature list of the 2960x.
06-14-2019 11:14 AM
Not sure what version of IOS you are running but top-talker command does not appear to be supported.
06-16-2019 05:29 AM
I run the Version 15.2(4)E7
06-16-2019 05:54 AM
Also the command is in the help of the CLI :
Switch#sh ip flow top-talkers ?
verbose Display extra information
| Output modifiers
<cr>
06-16-2019 06:12 AM
The command is in the CLI set :
Switch(config)#ip flow-?
flow-aggregation flow-cache flow-capture flow-egress
flow-export flow-top-talkers
