10-16-2019 12:08 PM
Good day all - please see what i used to attempt to gather netflow from a switch; my question here is - why do i see traffic from all my other branches from this one location?
flow record record1
match ipv4 protocol
match ipv4 source address
match ipv4 destination address
match transport source-port
match transport destination-port
collect counter bytes long
collect counter packets long
collect timestamp sys-uptime first
collect timestamp sys-uptime last
flow exporter export1
destination 172.24.5.25
transport udp 2055
template data timeout 60
flow monitor monitor1
exporter export1
cache timeout inactive 120
cache timeout active 300
record record1
Solved! Go to Solution.
10-17-2019 07:58 AM
10-17-2019 09:38 AM
10-16-2019 12:53 PM
10-16-2019 02:26 PM
yes an no - its a weird design, all branches connect to MPLS service provider (CE) using access port, so in theory yes. I was under the impression this would not work since it's a layer 3 service but i guess not. not as great as running on router but every bit counts.
MR.
10-17-2019 06:03 AM
Hi there here is the conifg; applied to vlan 1 - still seeing traffic from multiple locations, normal?
interface Vlan1
description old-data
ip flow monitor monitor1 sampler SampleTest input
ip address 192.168.3.9 255.255.255.0
no ip redirects
end
10-17-2019 07:58 AM
10-17-2019 08:40 AM
Thanks for the info Jaderson - its working fine now, after some research i notice that some of the other locations were also using the same UDP port (go figure....always over look easy!) i made changes and added some of your suggestions.
thanks.
10-17-2019 09:38 AM
