NetFlow on Catalyst 4500-E Series
SimGuy7474
Anyone know if a Supervisor 6-E will support NetFlow on a Catalyst 4507R-E?
If not, what are my options for NetFlow on a 4507R-E?
Marvin Rhoads
From : http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/53SG/configuration/nfswitch.html
...Supervisor Engine 6-E and Catalyst 4900M chassis does not support Netflow.
...To use the NetFlow feature, you must have the Supervisor Engine V-10GE (the functionality is embedded in the supervisor engine), or the NetFlow Services Card (WS-F4531) and either a Supervisor Engine IV or a Supervisor Engine V.
7 Replies 7
Marvin Rhoads
That's what I was afraid of.
I'm guessing my only options to have both 10 Gbps link capabilities AND NetFlow are to move to the Catalyst 6500 series then.
you dont have to move to 10GB sup engine to support netflow. As suggest you can buy daughter card netflow expasion module WS-F4531 for your Supervisor Engine 6-E instead. this option is cheaper.
I was under the impression that the WS-F4531 only was able to be used with either the Sup-IV or else the Sup-V engines?
http://www.cisco.com/en/US/products/hw/switches/ps4324/prod_models_comparison.html
My ultimate goal would be to support 10 Gbps flows with a 4500-E series chassis while also having NetFlow. However, it's seeming that it's not possible and that they are mutually exclusive on the 4500-E series chassis.
sorry yes you are right! While i was writing my suggestion it skipped my mind you are not using Sup-IV/ Sup-V engines
industriashaceb
Good Morning.
I have a switche Cisco Catayst 4507R+E and two Sup 7-E 10GE (SFP+), 1000BaseX (SFP), and i couldn´t configured the Net Flow, i was reading cisco forums, but in couldn´t find information important... somebody can help me?
I can´t activate the enable command #ip flow-cache, for activate in the interfaces.
thanks.
Cisc SUP 7-E supports Flexible NetFlow export. Can you try configuring as below and check. Remember to use IP Address as per your network.
flow exporter NFAexporter
    destination 192.168.1.1
    output-features
    transport udp 9996
flow record NFArecord
    match ipv4 source address
    match ipv4 destination address
    match transport source-port
    match transport destination-port
    match interface input
    match ipv4 protocol
    match ipv4 tos
    match ipv4 dscp
    collect routing source as
    collect routing destination as
    collect routing next-hop address ipv4
    collect transport tcp flags
    collect counter bytes
    collect counter packets
    collect timestamp sys-uptime first
    collect timestamp sys-uptime last
    collect interface output
    collect flow direction
    collect ipv4 id
    collect ipv4 source mask
    collect ipv4 destination mask
flow monitor NFAmonitor
    record NFArecord
    cache timeout active 1
    cache timeout inactive 15
Associate the monitor to the interfaces - Apply on all interfaces of the switch
interface GigabitEthernet 0/1
     ip flow monitor NFAmonitor layer2-switched input   - Will capture both switched and bridged traffic
Don Thomas Jacob
www.netflowanalyzer.com
NOTE: Please rate posts and close questions if your query has been answered
Regards, Don Thomas Jacob http://www.solarwinds.com/netflow-traffic-analyzer.aspx Head Geek @ SolarWinds NOTE: Please rate and close questions if you found any of the answers helpful.
