Hello, I understand you would not put Netflow on trunk interfaces because Netflow operates at Layer 3 and trunk interface is layer 2.
So, what about a standard port that is assigned to a VLAN (switchport access vlan x). Is this not also a layer 2 port ?
So would you put your Netflow commands here or only on the SVI for that VLAN ?
Thank you kindly.
