10-26-2010 03:40 AM - edited 03-06-2019 01:44 PM
Hi!
I have two Catalyse 4507 joined by an interface Giga. I implemented Netflow on the two devices with the commands:
ip flow ingress infer-fields
ip flow ingress layer2-switched
ip flow-export source Vlan111
ip flow-export version 5
ip flow-export destination X.X.X.X 2055
ip flow-aggregation cache destination-prefix
enabled
one of the Catalyst (switch1) export the data correctly but not the other, the output of the command "show ip cache flow" is as follows for each:
Catalyst that exports data correctly (switch1)
Switch1#sh ip cache flow
IP Flow Switching Cache, 17826816 bytes
35451 active, 226693 inactive, 3458800173 added
2192119154 ager polls, 0 flow alloc failures
Active flows timeout in 30 minutes
Inactive flows timeout in 15 seconds
IP Sub Flow Cache, 4227400 bytes
35451 active, 95621 inactive, 3458800173 added, 3458800173 added to flow
0 alloc failures, 0 force free
2 chunks, 3028 chunks added
last clearing of statistics never
Protocol Total Flows Packets Bytes Packets Active(Sec) Idle(Sec)
-------- Flows /Sec /Flow /Pkt /Sec /Flow /Flow
TCP-Telnet 6500127 1.5 17 88 27.0 3806765.5 24.1
TCP-FTP 8793339 2.0 36 65 74.0 3540083.8 20.8
TCP-FTPD 28618853 6.6 66 855 442.9 3893751.7 22.4
TCP-WWW 368569586 85.8 20 552 1741.7 3637226.5 23.2
TCP-SMTP 5036306 1.1 6 180 7.1 3323975.0 20.3
TCP-X 7116725 1.6 21 501 36.3 3677953.5 20.3
TCP-BGP 38 0.0 1 42 0.0 3955884.7 32.7
TCP-NNTP 139 0.0 2 44 0.0 3893273.7 36.5
TCP-Frag 12485 0.0 2 182 0.0 3033828.3 26.9
TCP-other 1675587396 390.1 173 821 67799.5 3779030.7 23.3
UDP-DNS 104429171 24.3 1 68 44.8 4251736.0 25.4
UDP-NTP 10270542 2.3 2 78 5.5 3856321.0 23.7
UDP-TFTP 37927 0.0 6 53 0.0 1533207.4 19.9
UDP-Frag 4419083 1.0 3514 1358 3615.6 3528393.2 21.2
UDP-other 894530949 208.2 18 478 3928.0 4030578.5 25.3
ICMP 327893020 76.3 7 66 608.4 3924877.4 23.4
IGMP 2149578 0.5 1 33 0.8 4.5 19.6
IP-other 724209 0.1 131 61 22.2 2183280.1 19.7
Total: 3444689473 802.0 97 815 78354.4 3854103.6 23.8
SrcIf SrcIPaddress DstIf DstIPaddress Pr SrcP DstP Pkts
Vl111 A.B.C.D Vl111 A.B.C.D 11 0B31 99CD 149
Vl111 A.B.C.D Vl111 A.B.C.D 11 809D 1220 1
Vl111 A.B.C.D Vl111 A.B.C.D 11 809D 1225 1
Vl111 A.B.C.D Vl111 A.B.C.D 11 809D 1229 1
Vl111 A.B.C.D Vl1 A.B.C.D 06 0AC9 0050 1
Vl111 A.B.C.D Vl111 A.B.C.D 11 0B31 99A5 273
Vl111 A.B.C.D Vl1 A.B.C.D 06 0916 0548 11
Vl111 A.B.C.D Vl111 A.B.C.D 11 99A5 0B38 373
Vl1 A.B.C.D Vl1 A.B.C.D 06 0548 11EF 3
Vl111 A.B.C.D Vl111 A.B.C.D 06 0050 1EE5 2
Catalyst that does NOT export data (switch2)
Switch2#sh ip cache flow
13 active, 262131 inactive, 283145053 added
2684798631 ager polls, 0 flow alloc failures
Active flows timeout in 1 minutes
IP Sub Flow Cache, 2130248 bytes
13 active, 65523 inactive, 283145026 added, 283145026 added to flow
1 chunk, 0 chunks added
last clearing of statistics 28w6d
TCP-Telnet 56480 0.0 8 58 0.1 1897750.5 13.7
TCP-FTP 2347 0.0 2 54 0.0 3085341.0 16.3
TCP-FTPD 5 0.0 9 1349 0.0 2576972.3 16.1
TCP-WWW 36672450 8.5 27 463 235.3 912618.3 18.8
TCP-SMTP 3660 0.0 2 51 0.0 2700190.9 16.2
TCP-X 5733 0.0 10 431 0.0 2397325.0 16.1
TCP-NNTP 1 0.0 3 50 0.0 1.0 15.7
TCP-Frag 1 0.0 1 210 0.0 4294957.2 17.9
TCP-other 86636487 20.1 17698 802 357001.8 2007449.3 15.7
UDP-DNS 84944 0.0 2 69 0.0 3868868.7 16.3
UDP-NTP 9695948 2.2 1 76 2.2 78130.3 15.8
UDP-TFTP 47 0.0 8 51 0.0 913841.0 15.6
UDP-Frag 129037 0.0 471 591 14.1 1918571.4 13.0
UDP-other 117227049 27.2 6 228 188.7 3144381.7 16.3
ICMP 2577353 0.6 48 58 29.3 3107174.5 16.5
IGMP 7283088 1.6 1 31 2.1 3.0 15.8
IP-other 2697048 0.6 90 47 57.0 438.7 14.3
Total: 263071678 61.2 5837 801 357531.1 2225531.3 16.4
Gi4/4 A.B.C.D Null A.B.C.D 02 0000 0011 2
Vl4 A.B.C.D Local A.B.C.D 11 007B 007B 1
Gi4/4 A.B.C.D Null A.B.C.D 67 0000 0000 1
Vl4 A.B.C.D Local A.B.C.D 06 0736 0016 28
Vl111 A.B.C.D Null A.B.C.D 59 0000 0000 2
Vl111 A.B.C.D Null A.B.C.D 59 0000 0000 3
In this case the Destination interface appears as null and Local,I checked the ACLs and no one is blocking traffic, there is not rate limiting configured... which can be the source of the problem for switch2 not exports data?
Thanks!
10-26-2010 06:06 AM
Hello Sdurn,
check if the second chassis has the required hardware modules
see
There are some type of supervisors that don't support netflow just to make an example
post show module from both to see if there are differences
Hope to help
Giuseppe
10-27-2010 01:31 AM
Thanks for the reply.
The two supervisors are the same model and have the same version...
