Netflow
shaikh.zaid22
Level 3
Level 3
I need to configure Netflow in Cat 9407 chassis switch.
I have a doubt whether the interface configuration can be applied to the port channel interface which is trunk ?
Since i have my access layers sw coming upto the core sw as a PO, and i want to send this traffic as a Netflow to a NAC vm hosted in the blade server.
Appreciate any help.
Hi guys,
Thanks @Mark Elsen and @balaji.bandi both your references worked in my case and am able to get the flow logs into my destination.
moreover, what i observed in marce's refernce, it is not mandatory to configure source in flow-exporter; based on destination address only, i was able to see the flows getting transferred to the destination.
thanks
5 Replies 5
Mark Elsen
 - FYI : https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9400/software/release/16-8/configuration_guide/nmgmt/b_168_nmgmt_9400_cg/b_168_nmgmt_9400_cg_chapter_0111.html#reference_FB2AAC4511A140CEBC384F64F86F4DCC
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
balaji.bandi
If you looking to use port-channel, you need to apply on the port-channel interface  (make sure the source interface can not be part of the destination)
example Netflow test on cat 9K switches.
https://www.balajibandi.com/?p=1383
BB
Thank you guys for the reply.
I configured it the cat 9407 chassis sw on PO member interfaces.
Do i need to mention the source interface is mandatory? becoz in the document attached below says OPTIONAL.
Also i did not mentioned the Netflow version, so by default it will take ver 9 ?
Please guide me. Since i can see on the firewall the traffic is going from the switch to the NAC VM.
Hi guys,
thanks
Glad that our suggestion helped to fix the issue.. if you looking more granular you can do source, if not all captured going to desitnation.
high-level example :
I would like to see only X  going to a destination  Y - then you only see that information data
if no X as source any destination going to Y will be recorded, this is depends on requirement and need for monitor
BB
