Network Equipment.
ConstanceS
Hi Guy's
I must decommission the following list below and need pricing for new stuff.
What would you recommend I use to replace each item in the list that of a similar spec but new.
Cisco 2800 Router            x1
Cisco ASA5520                   x1
Cisco AIR-WLC4402          x1
Cisco AIR-LAP1131AG     x2
Cisco 3560 Switch            x2
Kind Regards
Leo Laohoo
Router = Will depend on your WAN link
WLC: Cisco 3504
AP: Depends on your budget or AP2800
Switch: Depends on your budget or start with 2960X.
Julio E. Moisa
This is my personal point of view to be considered:
  New 4000 Router series
Cisco ASA5520                   x1
 Cisco ASA new generation 5545X or + or consider Meraki Firewalls.
  Cisco WLC 5508  or you could consider Meraki wireless solutions
  Cisco Aironet x700 or x800 aironet series or consider Meraki wireless solutions.
  Cisco 3650, 3850 or new generation switches 9300.
Now also you can use these links and select upgrade:
https://www.cisco.com/c/dam/assets/prod/switches/cisco-switch-selector-how-to/index.html
https://www.cisco.com/c/dam/assets/prod/routers/cisco-router-selector/index.html
https://www.cisco.com/c/en/us/products/wireless/index.html#~stickynav=2
https://meraki.cisco.com/products
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Thank you very much, really appreciate you taking the time to reply.
Leo Laohoo
WLC: Cisco 3504
